Most engines maintain stoich at cruise better than idle. Idle is tricky. Check you wideband at 2000 rpm light throttle cruise.
Doesn't need to be super accurate, just consistent. You are going to check your WOT AFR then makes adjustments from there. You'll find a number your car likes and you know that will likely be different than other cars.
