3.90’s FTW
Perfect for track and no problem on the highway.
What kind of power is the car putting down?
That’s a lot to the wheels for a stock bottom end car. Do some small changes it should be a very low 10 second car touching 9s at that power level.
3.90's even with a 26" tire? Since the car has a built 4l65e, i'd be maxing 3rd gear out at 127mph. I feel like traction would be none existent on the street then too lol.
It's around 610/560 to the wheels.
Must be a very happy dyno or the car has a shitty tune . 610rwhp auto Fbody should have been in upper 130's not 125mph .
I missed the part about this being a blower car, centrifugal blower? Do you have a converter? You should be able to cut that 60’ way down with blower power and a converter on a good tire
Sorry Im not an ass hole here as I have been around cars for years but no matter how you slice it, 125 mph trap speed is shit for an auto car that makes 610rwhp . Its not like you had a 2.4 60' . 1.7 60' is pretty decent , car makes 610rwhp on the dyno but the trap speed is like car that makes 100rhwp less . Here is a slip from my brothers 13 supercharged mustang on 8 psi , it made 600rwhp at this boost level . Similar 60' but look a the trap speed . Trap speed is an indiactior how much usuable power the car makes and uses the power going down the trackNumbers were on a mustang dyno and tuned my Mike @ Straightline performance, so no, not a happy dyno or shit tune. Ha. 125 isn’t bad for literally my first ever pass and rolling out of the hole. (Left around 1500rpm) Also, it ran such on a 25.5” tire and 3.23 gears.
Correct, it’s a D1sc and I have a Yank PAS 3400 converter. Yeah, a good tire is what’s holding me back.
What else ? Shitty power band ? I'd think a supercharged pushrod HCI 5.7 LS1 motor has a better power band comparing to a stock supercharged 5.0 Coyote but the track numbers show otherwise .We can't blaim the drivers here as both cars are autoSo those are the only two facts that could explain the differences in his and my ET/MPH? Shit tune and/or a happy mustang dyno.
I might be completely wrong here but I'd say both the powerband difference as in what RPM he is crossing the traps (i.e. gear/tire size) and the weather/DA that day all will affect on that.
With my 3.23's and 25.5" tire I was crossing the traps at like 56-700 RPM. I don't make 600rwhp until redline at 64-500rpm. So it still has more mph in it. Like everyone else said, the right gears, drag radial and suspension tweaks my ET/MPH will be more accurate compared to my HP numbers.
when your car hooks hard the trap speed will most likely be slower, his brothers car has 3.15 gears and im sure a taller tire than 25.5, good da wont pick up 10mph
could it be the 4 speed vs 6 speed?
that 2nd gear in the stang trans being a 2.43 to 1 is going to keep that car in the power band much better than the 4l60e's at 1.63...
stang:
3.66
2.43
1.36
1.32
1.00
.65
4l60
3.06
1.63
1.0
.70
My car might be different because the better 60' I get trap speed is higherwhen your car hooks hard the trap speed will most likely be slower, his brothers car has 3.15 gears and im sure a taller tire than 25.5, good da wont pick up 10mph
peak horsepower numbers are silly
