Does your gas cap/surrounding bezel say "E0-E15"?
Something like this:
If so, you have found your answer.
I will agree, you'd think they'd put the "contains ethanol" sticker on the blue button to warn dumbfuck Karen that her 1998 Corolla will not run on 88 because clearly 88 > 87 so it must be better.
A waste of tanks and money, is what that is.
I've scanned a bunch of rides recently that are supposedly on e10 gas but the sensors showing mid 30s for content. Either gm sensors have a universal issue or they're using the ethanol to make up for how bad the base gas is is my guessUnleaded 88 is just how they are marketing it. It's e15. Use it.
I often put e30 in our edge, even though it says e15 max.
Water in the fuel will skew how the sensor reads too, so it's probably not actually that high.I've scanned a bunch of rides recently that are supposedly on e10 gas but the sensors showing mid 30s for content. Either gm sensors have a universal issue or they're using the ethanol to make up for how bad the base gas is is my guess
Then there's alot of water in that shit ?Water in the fuel will skew how the sensor reads too, so it's probably not actually that high.
