Hmm.. maybe thats where some of my exhaust leak is coming from, plus shitty mileage... Pacesetters and trying to keep EGR = fail?
pacesetters = fail.
did you weld them?
When was the last time you changed your O2 sensor? I saw a big jump in mileage and i deleted my EGR and changed the O2 at the same time.
The EGR if removed will cause a decrease in gas milage. It purpose is to slip in inert exhaust gasses to cool the head temps during cruising when running at the A/F stoic ratio (14.7:1). They do this to reduce NOx emissions that occur during hotter head temperatures from the leaner A/F ratio. It is only active during mid-throttle cruising. If you remove it you will run slightly hotter due to higher head temps. The atomized fuel vaporizes sooner as it enters the hotter cylinder head reducing it effectiveness. (You want the fuel atomized in the cylinder and then to vaporize as it compresses for the most efficient burn/power.) The O2 sensor sees this as less fuel so it richens up the mixture and you use more fuel. If it did not richen up the mixture, The head temps would get too hot and lead to other problems.
Did you re-program the PCM for no egr? You also need to change the timing advace curve slightly to compensate for the change.
Some engines don't have an actual EGR valve, But rather an EGR passage between the intake and the heads. If I recall some (or all? ) of the LS series engines have this.
Engines built without EGR's do not run the cruising A/F at 14.7:1
Little more descriptive on these timing changes. I am running some weird table that Mike recommended to Kyle back when he had his SSEi and i see some weird part throttle KR at partial throttle going up hills (under load).
Just out of curiosity, Why is everyone deleting the EGR? It doesn't affect power because it only works at part-throttle cruise. The rumor that removing it for more power is false. That only works on pre-1982 vehicles.
Guy's with intercooler cores between there blower and LIM do it to keep the core clean. My removal is just temporary.
It is probably due to the torque convertor still in lockup. It is normal.
There is a hidden spark modifier table for this condition based on mg/cyl vs RPM. You can pull some timing to compensate.
What is your OSID?
