Running that in my LS 6.0 swapped 83 Regal......At 1100 the holley term x is the best bet.
Consider an MS? Lots of tuning support for it out there and friendly to the DIY type.
But 90% of all drivability issues are because of the 30yr old + harness in these carsAnd the PimpX is MS3-based, but can plug right into a factory mustang harness. So minimal wiring needed.
PiMPxs Standalone Engine Management (Sequential EFI)
PiMPxs Standalone Engine Managementwww.stinger-performance.com
Get an Aeromotive 340 and stick it in the tank with a new harness if you're dropping it. That's a lot like work to do so you may as well set the next guy up. You'll be ready to split the block if/when you decide to get silly.
Then again it may just be a sock too but why chance it?
Oh and a TFI Module in these is ALWAYS suspect. Even a new one.
You’re falling down the rabbit hole?Aeromotive 340 pump on the way!
I'm putting my money on this showing up to TCG track day and running a sub 11
Didn't post the update picture last night. Getting the stock exhaust out SUCKED. One motor mount bolt and it's ready to come out.
Need to figure out if the water pump needs to be changed... The Cobra pulley from the 92 doesn't fit the 94 pump.
Need to look at the speedo situation, I think the t3550 will hook up to the mechanical cable, but not sure?
Need to decide which rails I'm going to use. The 92 rails are more anemic than the 94, but not sure if the quick connects are compatible or not...
Need to pull the stock air filter assembly, Cowan the engine bay up a bit and touch up paint stuff, and basically God knows what else.
Chip is on its way to have a base tune burned... Dyno the week of the 28th!
You probably have inside info.ill take that bet
