mclovin, buddy, you both need to stop tuning those cars until you get a wide band on both. Your car looked alright to me besides running out of in injector but... this car is so incredibly rich its not even funny, i bet the plugs are fouled out now. I'd take a look at them before proceeding for sure. The reason for the instant knock is highly doubtful that its the trans. Usually when its the trans its a blip not a constant, and i know he has solid motor mounts so the engine isn't rocking around. There is a point right before the car enters pe, you need to find that maf frequency there and use the maf frequency to richen that part up, thats the ideal way for that but... 1000 o2's?!. What kind of timing is it commanding right when it enters pe mode? that also will be a contributing factor. I'm done trying to get him to put on a 3.4 because obviously he won't after pretty much everyone on here told him its not the tune, so the only way to get rid of that knock is keep running it horribly rich, and pull all the timing out. Set the timing to 10* and pretty much all kr is gone, but don't lean it out or it'll start knocking again. If the car pulls like a mule with crappy timing and nasty afr's then imagine what it would do on a 3.4 with 11.7 afr and 20* of timing with no kr...?? Someone tell me i'm wrong, because i'm starting to believe i am, if i was right he would have listened correct?? i will personally donate $20 towards you buying a 3.4 pulley will that help? If i had one, i'd give it to free of charge because i'm not trying to be an asshole, i'm trying to help.
