Diff Pinion torque?
01bluesnake
D Mark Performance
3,404
7,556
Thanks, so is a new crush sleeve required when you take off the companion flange???
proper way= yes
quick and cheap way= no
if you count the tread amount and mark the position of the nut before removal, you can reinstall in same spot with no issues. if you are installing a new pinion seal this will work, if new flange then i wouldn't use this method. this method has been done alot, and 0 no issues to date.
  • scca_stang
  • 3
  • 465
