I think that's a dig @ poor Bill. So low.
The fuq does PC stand for?!
The PC can be effective as a paint correction tool. Just depends on the pad/compound. I used an LC yellow pad and M105 on my buddy's old maxima a few years back to remove some deep scratches and oxidation. It worked flawlessly. I had to be careful too because with that heavy of a pad, it would dull the hell out of the surface. Never burn it tho.
I used the LC orange pad and M105/m205 on my cars for years. Got glass like results. It was only when I switched to a rotary with the same mindset I had for using the PC, was when I burned the mustang. I should have never switched from the PC. I was able to even buff out 2000+ grit wet sanding marks with it. Watch Junkman 2000 on youtube. Hes the PC and Flex master. Tons of videos wetsanding and buffing with both the PC and flex. Lots of great info.
https://www.youtube.com/user/Junkman2000
So this is what you burned your paint with? I have used it on my cars, but I didn't go as long as the video on the first page. I feel like if I went that long I'd screw the paint up something furious.
I used that big fluffy one in the picture I posted. It turned out pretty good, but there were some swirls on the hood of my s2000 that I had to get rid of.
If you use a finer compound it will not swirl as bad
The problem most people have with rotaries is that they grab a wool pad and rubbing compound and thats where things can go bad quick. A nice soft pad and light polish and keep the buffer moving and you will be fine.
Which flex kit would people suggest from Autogeek? Something like this?
Wolfgang FLEX XC3401 Ultimate Polishing Kit
