I'd ask [MENTION=2933]Thirdgen89GTA[/MENTION] what the traction control was set to during that data log, because it looks like you spun for a good amount of 1st, and maybe chirped 2nd, but otherwise had no spin.
Might help answer [MENTION=2612]Pressure Ratio[/MENTION]'s question as well.
It was in "Doesn't save your bacon mode". TCM, STM were fully off. The PCM still had its brake based E-Diff active though. Ford calls it Torque Vectoring, since it basically increases performance all the time, you can't turn it off.
The wheel spin in at the beginning was on purpose. It was a 2nd gear roll-on, it basically spun from about 15mph to 50mph when the boost hit. You can see a small spike in the boost as it starts to rise, then the boost doesn't increase as rapidly because there isn't much load while the wheels are spinning. Turbo responds pretty quick at low-revs and hits hard.
Focus ST does not have any torque management in Cobb tune, which is what was run there.
The Focus ST's throttle map by default isn't linear. The Cobb tune's map is linear and 100% correlation between pedal position and throttle blade position. Whatever your foot commands is what the throttle blade does.
I do have Waste gate opening in the datalog, but didn't post the numbers with it. I could post the log if anyone wants to see all of the items, but its a lot of data points.
