Car wont start
ThirdgenTa
So my girlfriends 04 Mach1 won't start. Thought it was the battery so I warmed it up, re installed it and it just cranks. It sits outside all the time so I figured it might be a frozen fuel line or something. Jeff told me to take the cap off the fuel rail and push the pin. Some fuel comes out put not a lot. Apparently it refuses to start every winter and it's her only car. Any ideas?
EmersonHart13
Member Selfie
Have a garage? Push it in and see if that helps?
Any fuel line anti freeze used?
10sec
With proper tires any car is capable of traveling safely in snow.
ThirdgenTa
Drives Mach 1 in the snow? Potentially slipping and sliding all over the place? :nice:
No she doesn't drive it in the snow. I was going to drive her to work the other day when it was snowing, but now I am driving her every day since it won't start.
EmersonHart13
Member Selfie
Sometimes you get lucky. Anyway when the fuel pump is cycling it is going to move it around. Can't hurt?
IceCreamAssassin
FBMM
Cary
Not always... It takes moister out of the fuel... So if you grab a few and dump them in eventually it will work its way through the system. Trying to start it and having the pump run will help push it through as well. Just takes time.
Frank Dukes
Rockfordia
ive seen a few cars not start and then heet added and finally kick over. if your priming it enough the heet will get where it needs to go. not surprised its tough to find right now though, always happens at first weather break.
RICH17
Dr. Pussy Slayer, MD
The 007
Get the red bottle heat as well Brian. I also assume its a fueling issue
EmersonHart13
Member Selfie
Use some high quality gasoline and keep running Heet.
Intel
Palatine
If it happens every winter might be time to look into why you have water in it's fuel system to begin with.
EmersonHart13
Member Selfie
Yeah if she is going to do that you are going to need to use HEET a lot more often.
Aron
Scared pussy
Tell her to keep her gas tank topped off the best she can. The lower it is, the more moisture/condensation can build up in the tank and eventually get into the gas and...freeze. Same reason we keep our bike tanks full in the winter.
Zack
4 Doors 4 Life
NW Indiana
I've been driving every make and model since 1996 and never needed HEET.
My 76 Caddy would start right up in -20 temps.
I have always gassed up at Amoco though (now BP obviously)
EmersonHart13
Member Selfie
I think you only need HEET if you bought cruddy gas. Otherwise your car should be able to cope with it.
ThirdgenTa
Well it's been working fine ever since, except some 15 year old nailed her car while she was sitting in a parking lot waiting for me.
