all this is reminding me that my snowblower is fucked.
last winter the starter pull cord decided to not be part of the team on mine anymore.
If you happen to have gas from 1965 it would still probably fire off in a car since they used lead and no ethanol back then the gas lasted a lot longer, that 10% ethanol causes the gas to absorb water at a much faster rate, plus I have yet to test my theory but I’m betting they are using more than 10% even though they aren’t supposed to there’s a great road kill video that talks about the ethanol in the gas as they are forced to rebuild a carb that’s been sitting with 93 in it for maybe a year due to corrosion
Why full tank of gas ? Won’t the gas be old in 5 months and be bad for the car ? Thoughts everyone
Since no one has mentioned it yet, I've read some guys will put the car up on jack stands to avoid flat spots on tires. I also wonder if spraying some fogging oil in the combustion chamber might be a good idea. Keeps the rings lubed up. This is more common with boats, but see no reason why it wouldn't help with cars.
Personally, I give it a bath, full tank, fresh oil change (it was due), hook up battery tender. That's it. And maybe start it from time to time.
