Bleeding Brake Lines... school me please!
DSG03COBRA
1,746
Plainfield, IL
So whenever I change the brakes, I don't usually bleed the brakes. Well, I had to replace a caliper this time, so I know that I MUST bleed them. I think I remember reading about it before and people saying that it's a fairly easy task to do, especially if you get one of the "one person bleeding kits" or something like that. Anyone care to give me some info on this job? Maybe a "Brake Line Bleeding For Dummies" :confused: Thx!
CREJoe
Chassis Builder
Jun 15, 2007
96
If you only replaced one caliper (and swapped it quickly), you only have to bleed that one corner. As long as the level in the master didn't drain down to permit air to enter the system (as is the case if the car sits for a while with an open corner circuit), you should be fine.
DSG03COBRA
1,746
Plainfield, IL
Yeah, that's what I figured I needed to do, but have never bled the brake lines before. I found a few videos online and it really doesn't look very difficult. Worst part should just be pulling off the wheel to get to the bleeder valve...
nytebyte
Not Politically Correct
Mar 2, 2004
13,706
21,236
Those instructions say to pump the brake pedal 15 times.
I always thought that you weren't supposed to do that because it may cause the brake fluid to foam up. I always just press down once firmly on the pedal, then open the bleeder.
Seems to work.
