looking at the dewalllllt of course, the toro one looks interesting, EGO power has great reviews. etc.
DeWalt one is allegedly not that good. the new Toro FlexForce and the newer self-propelled Ego's are getting really good reviews depending on your SF.
actual area that will need to be mowed looks like it's under a fifth of an acre.
kinda "technical" with lots of turns/nooks/crannies with one solid hill
I think the Ego with the 56 volt/5ah battery has like 45 minutes of run time. But lawn length, density, etc. will impact this. Also not self-propelled if that's important to you.
How many speeds did it have? Most newer ones today are that personal pace or a variable speed setup.
I actually have mine in the slowest setting to let the blade and the mower do it's thing.
Ego Select Cut essentially copied the Honda Twin-Blade system, which is best in the biz for mulching as of late. Additionally, Toro just added a SuperRecycler version in the 60v line I'd look at as well.
- Select Cut™ Multi-Blade System for premium cutting performance that exceeds gas
Toro Super Recycler 21 in. 60-Volt SmartStow Max Cordless Battery Walk Behind Mower- 7.5 Ah Battery/Charger Included 21388 - The Home Depot
The Toro Super Recycler series has a patented cutting technology in which the Recycler cutting system creates Lawn Vitamins out of your grass into ultra-fine clippings and then it nourishes your grasswww.homedepot.com
that one you're talkin bout?
Yes, SuperRecycler is Toro's competitive option to the Honda TwinBlade. Additionally, I'd recommend NOT cutting at full sprint lol. A super fast cut is not a quality cut. Ground speed is important to allow the mower deck to lift the blades and cut them efficiently.
I have one. It's is not only the fastest self driven mower I've ever used, it's never bogged down like all of our other gas mowers. Especially this one part of our lawn where the grass seems to grow faster than anywhere else.
I keep the batteries inside for winter and having no maintenance, and I mean none, is the best part about it.
