97 Blazer delayed/hard shifting
Aron
Scared pussy
I have a 97 Blazer 4x4 - 4.3 w/4L60e.
On my way to KOTS Saturday I noticed when I got off the tollway that when pulling away from stops under normal acceleration, the 1-2 and 2-3 shifts were delayed and very hard, almost like it had a shift kit. We stopped for lunch for half hour, and when we left it was shifting normal (I assume because of a cooldown period). A couple miles down the road, after getting back up to operaring temperature it started doing it again. Eventually I got a SES, but I periodically get one for O2 sensor, so I'm not sure if it's related. On the way home it did the same. Later on I stopped for a hour or so, then drove home about 12 miles. SES cleared and it shifted normal all the way home.
Yesterday and today I drove the truck and no problems, but I didn't go far.
Any ideas?
2003_svtcobra
when was the last time the trans was flushed and filter changed? and how many miles are on it. but it sounds like the trans is on the way out.
IZZy
Powered by ES
Unplug a coil and see what I does
superman
COME & SEE
if u unplug coil u will find motor is blow dont do it..... are u certified?
Aron
Scared pussy
It has around 125k. I'm not sure of the service records since I've only owned it for just under 2 years.
I'm thinking it's more of an electronic problem than mechanical since the shifting is electronically controlled by the pcm.
01Cobra
Johnny Cobra
trans is taking a shit.
My buddy''s blazer (blazay) has same issue and its the trans. He has had nothing but troubles with it since hes owned it.
Aron
Scared pussy
Yes Blazer racing season starts in a month or so lol.
I did a search on the Blazer forums and it's looking like it may be the TPS.
Sounds like the trans is on its way out. We use to have a caravan and those where the first signs of when the trans took a shit.
