đź“° Auto News 562 hp Hennessey Camaro HPE550 is the Z28 that never was
118,926
The Chevrolet Camaro Z28 may be stuck on an indefinite holding pattern, but Hennessey Performance is one of the first aftermarket firms to step up and fill the void between the base SS and Henessey's own 705-hp, ZR1-powered Camaro HPE700.
The Camaro HPE550 begins life as a standard SS model, and with the help of a Magnuson supercharger and a Corsa exhaust, the blown LS3 puts out 562 hp at 6,200 rpm and 557 lb-ft of torque beginning at 4,200 rpm. Hennessey is claiming a 0-60 mph time of 3.9 seconds (down from five seconds on the standard model) and a quarter mile pass of 11.9 seconds at 119 mph.
The entire HPE550 package, which also includes high-flow fuel injectors, an aero package and aluminum wheels, will set you back $24,950 plus shipping uninstalled, or $31,000 installed, not including the cost of the donor car. If that's not enough, you can send your new SS to Hennessey for the aforementioned HPE700 package, or go completely nuts with either the 850 hp or 1,000 hp twin turbo setup that will set you back $54,500 or $59,500, respectively – again, not including the cost of the stock Camaro SS.
Sinister Drag Designs
SinisterDragDesigns.com
Aug 3, 2007
4,876
Chicago, IL
11.9's is for the cheapest package which is kind of a rip off.
So from what I read you buy a 30-40k car and spend 60k to get a 1000hp TT camero? How many other cars can you spend 100 g's on, get 1k HP, look that unique, and still be under warranty? Im guessing the cameroHPE1000 would kill the Zr1 in a straight line and pull in more tail doing it. :dunno:
Turk
Lt. Ron "Slider" Kerner
28,518
7,969
OH NO YOU DIDN'T!
