4g63t problems..never ending
KaMaSuTrA
Resident Sexi Man
Aug 22, 2008
1,485
Chicago IL
yeah so i was thinking i should just buy a cam sensor from a 1g right?
Sounds like that should do the trick, it will require some rewiring to make it work.
http://www.roadraceengineering.com/1gcasin2g.htm
http://www.magnusmotorsports.com/tech/1gina2g.pdf - Bottom portion regarding 1g cas on 2g
Just FYI...
90-94 CAS were just slotted and lined up with a slot on the cam (No threads in the cam) Located on the passenger side of the head. The are round in shape.
95-96 CAS was bolted under the intake cam gear. Located on driver side of car.
97-99 CAS Was BOLTED to the intake cam, threads inside the cam, and was lined up with slots (1g style)Located on passenger side of motor. The are like a triangle in shape.
Do you already have this engine in the car already?
  • 9
  • 8
  • 456
