4.6 misfire
machausta
Slow VW driver
Eastern Tennessee
:fu:
Ok, I'm getting pissed off about this issue.
Driving to work last week the car started to misfire about 15 minutes into my commute, I grab the xcal and it read P1132 LACK OF SWT RICH
So I checked plugs, wires, etc...and pulled the MAF because I've suspected for awhile it was an issue, the misfire went away through the RPM range but the car barely idled. Replaced the MAF with another KNOWN GOOD unit from another 95 T-Bird 4.6. Car seemed to be a lot better the next day, until about 15 minutes into driving when the misfire returned. I drove to work and pulled codes again P1131 LACK OF SWT LEAN P1132 LACK OF SWT RICH
Both codes are HO2S1, so I instantly assume its the O2 sensor on bank 1 (drivers side)
Replaced
Car idled like shit this morning, first time driving since I put in the new O2.
Pulled the ECU fuse, plugged it back in, still misfiring -- P1132 P1131 both returned.
WTF??? :angrys00ls:
Dasfinc
Mrrrrstang.
Wheaton, IL
Ditch the stock exhaust *you know you want to*, Ditch all the cats, Tune out the EGR system and rear O2's if you have them.
If you STILL HAVE cats, You have probably destroyed them with the tune/abuse/headswap/etc on stock nearing 100K system.
SaturdaysGS
Chicago (Southside)
Maybe I misread, but does the car misfire then throw a code or throw a code then misfire? Or does the code and misfire happen at the same time?
machausta
machausta
Slow VW driver
Eastern Tennessee
The misfire is setting off the code. Its not the coil pack, and the car runs perfect when cold, after about 15 minutes of driving its misfiring constantly. I do have a cat that rattles, but it seems to be normal temperature-wise and the car is always fine above 2500 rpms...
machausta
machausta
Slow VW driver
Eastern Tennessee
What EGR/Rear O2s? They were tuned out with the headswap.
Again I would think the car would drag ass when you step on it, but instead its perfectly fine.
Dasfinc
Mrrrrstang.
Wheaton, IL
Could still be the cats *shrugs*
Check plugs/wires/pack
injector clogged/streaming/sticking?
maybe swap injectors to the other bank and see if the codes switch over to bank2
machausta
machausta
Slow VW driver
Eastern Tennessee
Update: Cleaned up my grounds and the problem is 95% gone. Still a very slight studder at low idle/rpms but tons better than what it was. Could actually drive the car in overdrive on the interstate today.
