2003 Black Cobra Coupe F/S
I really hate to sell my cobra but the time has come. Here's the list:
-2003 Black Cobra Coupe - 22,790 miles
-Tan seat inserts
-Stock chrome front rims, AFS reps on rear 17x10.5. 275/40/17 nitto 555 front, 315/35/17 rear Less than 2000 miles on tires.
-2 pod a-pillar gauge cluster w/ autometer boost/vac combo, autometer fuel pressure gauge, and raptor shift light. I also have a never used autometer water temp gauge which I'll include.
-Hurst roll control line lock
-Accufab single blade throttle body w/ plenum, both polished
-2.2L Kenne Bell blower w/ 15 psi pulley installed and 8 & 19 psi pulley included.
NOTE: I AM INCLUDING THE STOCK EATON
-KB Boost-a-pump
-60# siemens fuel injectors
-JLT Cold air intake.
-Diablosport predator tuner w/ DS MAFia
Tuned by James @ RWD
-Centerforce DF clutch w/ centerforce aluminum flywheel steeda firewall adjuster and steeda quick release clutch quadrant
-26 spline input shaft
-LDC cooling h2o mod
-Pro 5.0 shifter
-Kooks LT headers with kooks x-pipe, magnaflow highflow cats and borla stinger cat back
-Gords twin fan heat exchanger (NOTE: fans are not wired)
-MM full length subframe connectors
-Solid rear axle built by Aaron Stapleton of Fast Forward racecars:
Stock ford 8.8 housing
Chassis Engineering Advantage mustang control arms
Chassis Engineering AM anti-roll bar
Mosier 31 spline axles
Stock axle studs
3.73 gear set
Tru-trac posi unit
wilwood pro street brakes w/ parking brake
9" axle ends
FFW 8.8 round tube housing brace
Chassisworks big ford housing ends
Strange 10-way adjustable coil over shocks
NOTE: I AM INCLUDING THE STOCK IRS WITH THIS CAR. Including shocks and springs. Needs new brakes from sitting for two years though.
-Maximum motorsports tubular k-member, tubular control arms. Koni adjustable coilovers. MM caster/camber plates. MM oil filter relocation kit.
The MM setup was installed by Aaron Stapleton of Fast Forward Racecars: http://www.fastforwardracecars.com. Sutton HP adjusted and aligned it for me.
NOTE: I HAVE THE STOCK K-MEMBER, CONTROL ARMS, SPRINGS AND SHOCKS AND WILL BE INCLUDED. No brakes.
============> $28,000 FIRM NO TRADES
NOTES: The pic of the solid axle is Venom27's car. I do not have pics of mine but they are identical setups. NOR do I have pics of the front end setup. In fact I can't remember the last time I took a picture of anything, but ask and ye shall receive.
Anything that I've said is included can be extracted but doing so will not lower the price.
I do not have dyno numbers or times with the KB installed. Pre-KB numbers and times are in my sig. Car has NOT been raced with the KB.
I will try to post more pics in the coming days. Anyone is welcome to come to Joliet and have a look. I don't think I've left out any mods but I'll edit if I did. Thanks!
EDIT: I will also include an Innovate Motorsports LM-1 wideband o2 sensor that will log data but it is not installed.
