🔧 Technical Traditional Hose Clamps vs T-Bolts
greasy
37,003
29,173
When my kit was built, it was pressure tested to 35psi, in my own garage, with ZERO leaks.
Do you want a medal?
What the hell is the point of sharing anything on here if it becomes a pissing match? I posted this as an informative thread. [MENTION=340]Eagle[/MENTION] builds better cars than AMS. Take your GT-R's to him so he can build them in his garage better than AMS does.
Bob Kazamakis
I’m the f-ing lizard king
85,589
45,907
Joel
Breeze makes the best t bolts
Eagle
Nemo me impune lacessit
63,909
4,744
Woodsticks, IL
You have not offended me, I am just not sure what you are arguing. I think you didn't read the article and then made a statement to argue a point that was not being debated.
Not arguing. Stating my own experience. Didn't need to read the article, but even AFTER reading the article, I'll stand firm with the results from my own experience, experimentation and results.
greasy
37,003
29,173
"Over our 10 plus years I get this question all the time. Why don't you use T-bolt clamps instead of traditional worm gear clamps.
The answer is that when coupled with the right sized pipe, the right silicone coupler, a proper beaded end for that pipe and a high quality clamp you will actually get a better sealing area. In addition T-bolt clamps can often distort or crush most aluminum piping causing a bad seal.
Omega is a perfect testament of this as despite how much boost we throw at it we have never lost a pipe or popped off a coupler."
T-bolts vs Traditional Clamps... An explanation - Engine - GT-R Life
"Thanks for posting that Ian!
We have used just about everything (T-bolt, Murray Constant tension, etc etc) and the worm gear clamp we use we have found to be the best option. If you are stripping a worm gear clamp you are either tightening them too much or using a POS clamp. Also if you are "cutting" into the material you are clamping on as Doug eluded to you are using a crappy coupler or again over tightening it.
The pipe design is just as if not MORE important than the clamp. Use a high quality worm gear clamp with a good bead roll and you will be fine.
Omega has seen over 40psi on many occasions without a single issue. Our old EVO VIII saw over 50psi for two years.
Eric"
Something as basic as clamps. - DIY, Maintenance, Technical Support - Nissan GT-R Heritage
GIMPY
1,103
One of the most expensive builders when it comes to GT-R is pushing cheaper worm clamps?
Makes zero sense.
I have no idea y u guys are bitching about worm clamps vs t bolt clamps.. one of the biggest problems with the t bolt clamp and I'm sure most of us have done is over tightening a t bolt clamp onto this aluminum tubing which results in crushing the tubing. now if I were ams and building kits like they do I would put worm clamps in every kit to. reason being its way harder to over tighten a worm clamp and smash the tubing... oh and if people are that worried about a clamp then shell out the cash for wiggins clamps and be done with it...
greasy
37,003
29,173
I think you are misreading me. I made this thread to educate people on something that I was informed about. Then people got on their T-Bolt high horse suggesting what I posted from AMS is nonsense.
GIMPY
1,103
actually wasn't intended toward u really... mostly ctcdeezul.. he shows a cast aluminum part with 2 tbolt clamps... I guarantee if he pulls that part off and measures the wall thickness its either 1/8 or 3/16th thick.. cast wont deform like aluminum tubing will..
Pressure Ratio
20,518
12,441
Glen Ellyn
Quoted some stuff as I was reading and some of it was covered already. But anyways...
I do not see the point in spending money on T-Bolts and possibly deform the pipe, when I can bead the ends and run good worm drives at a fraction of the cost.
If you are deforming the pipe you are either using thin wall / junk material tubing or tightening the clamp too much.
I think people like t bolts because they strip or ruin worm style clamps when trying to tighten the clamp too much.
May times the tubing finish and/or the type of coupler being used is the problem. I see guys polish the aluminum and stainless tubing. That is not an ideal surface for the coupler to grip. I have seen cheap couplers that are made of a material that is hard. They don't grip the surface of the pipe well at all.
Rolling/pressing a bead in the tubing is a huge help. Eastwood and other tool companies make a nice bench top version that is about $150 and works well. You can even buy a cheap hand tool that works well enough for the home mechanic to be able to do this. Hell I have seen guys make their own tool that worked well enough. Bead rolling the tubing should be a no brainer.
Using a strap to hold one tube to another helps reduce the forces trying to separate two tubes as well. So the coupler and clamp have less work to do. It isn't uncommon to see people use these as well as bead rolling the tubing. Especially since a small strip of metal, two bolts (or studs), two lock washer and two nuts are all that is needed.
They make lined worm clamps that will not chew up couplers. Don't buy auto parts store garbage.
The issue with the lined worm clamps is the small surface area where the worm gear and slots in the strap provide. It is only the thickness of the strap, which isn't much. These end up deforming, slipping and stripping. Another reason people prefer t bolts over worm gears. But like you later mentioned there are the ones where the strap has a raised section where the worm gear rides. Allowing for greater contact area and a better working clamp.
Price is only one aspect of the equation and it is not even the main point. Price does not keep boost in the pipe.
Price is always a consideration. If it wasn't everyone would have V bands, Marmon or wiggens clamps on every thing they own.
I think Steve was also hinting that the part of the reason AMS uses worm clamps is so the customers can't crush the tubing by over tightening them. If they can't crush the tubing they don't have to worry about replacing anything. If they design the kit well enough they should be able to use a good worm gear clamp and have less worries about customer issues.
GIMPY
1,103
that's basically what I was trying to say... not to mention its also easy to find worm clamps anywhere and everywhere if u need to replace one..
