if my hopes and dreams of bugging out of IL fall through I kind of want to put a wood burning stove in the garage, something small but you can get them with fans that will blast the heat out.
Yessir. I get that isn't good for you.
Condensation, it sucks.
cliffs, ventless makes moisture. Because it is a closed system the vapor is trapped.
If you keep constant temps low and open door or windows sometimes you'll be fine. Like parking a car in the garage daily should be good enough I'd think.
I had a propane torpedo heater before and when I would use that I would crack a window while it was going. No issues.
I have a Beacon Morris unit from Menards. I went with the biggest one I could walk under.
https://www.menards.com/main/heatin...4424894441-c-6865.htm?tid=2561955605759424971
I keep my garage at 40, when motion is detected in bumps to 50 via my NEST. I also have a door switch so the heat turns off whenever the garage door is opened.
Let's talk about your gas line. Size location and ability to T off of it. etc....
Gas is a volume based not pressure based item. So to have enough gas to run multiple BTU appliances you need to have a fat pipe as the pressure is static and quite low on NG. Also the longer the run the larger the pipe needed.
Don't get scared on me.
Then there are the vent upgrades, yuck.
They make tankless heaters that condense and only need PVC for the venting too....
Other than that is double wall stainless needed if memory serves?
