Power Tools Discussion
FESTER665
40,169
66,695
What exactly would you crimp with this?
Large lug terminals for power distribution on trains....
We've done a few power boxes for trains as well with large breaker panels, they had slightly lower gauge but still larger than most.
greasy
36,963
29,120
FESTER665
40,169
66,695
I think I'm going to need to buy a 1/2" version to get the god damn seat belt bolts out of my car... Those mother fuckers ain't moving with my 3/8" impact in the least or with a cheater bar on them... :bowrofl:
Going to soak them with penetrating oil and try an impact next I think.
Got one I can try [MENTION=60]greasy[/MENTION]? :s00ls:
FESTER665
40,169
66,695
I just couldn't believe how stuck the fucking things are. Going to get under the car this week and wire wheel the bolts to make sure they're clean and then soak them to see if that helps....
I may hit you up to borrow one though just to see if itll break loose. I just ordered a 1/2" impact T50 torx bit for the attempt. :bowrofl:
FESTER665
40,169
66,695
Umm. Their loctited in. Heat the threads/bung. Will come right out
Umm. It's "they're". :s00ls:
The torch is there as well, there's just a lot of flammable stuff there so I want to use it only if absolutely necessary.
I wonder if a heat gun would get it hot enough to break down the loctite, I always just use a torch because it's usually not surrounded by open fuel lines or insulation...
