it was a joke.
I think the general public really believes companies actually "hide" profits!
it was a joke.
Except that I will have probably anywhere between 40-50 items that I will want to look for, not just cells that contain "PAYROLL".
ok i got it to work. i was right on the search wanting a single value, the thing is the match goes through the list and does the search on every individual value. then you get an index if it's found and the other shit uses that as a lookup to put in your output value.
it will probably get slower if you have a large list, but hey, shit's probably fast enough for what you are doing. also it looks like if you put an object in the list twice, it simply uses the first value.
if you wanted a more dynamic string pattern matching thing, you could probably write your own little excel function with vb.
here's the key part you are missing:
This is an array formula and must be entered with Control + Shift + Enter.
I believe some companies might try and hide some upside if they're having a good month. They may dump something into a balance sheet account for a rainy day.
This is an array formula and must be entered with Control + Shift + Enter.[/I]
I am a bit rusty with excel but I helped a friend with something similar to this.
VLOOKUP is your friend for this.
=VLOOKUP(C2,C517,2,TRUE)
This formula says to look for the value in C2 in the range C5:C17. If the value is found, then return the corresponding value from the same row in column D.
https://support.office.com/en-us/ar...pitfalls-0b22ff44-f149-44ba-aeb5-4ef99da241c8
I'm not sure I get the array formula thing and how it must be entered with Control + Shift + Enter.
Where might I find a decent tutorial on vb? Is that Visual Basic?
Function SigFigsMike(rng As Range, Optional iType As Integer = 1)
'iType = 1 is Precision
'iType = 2 is Scale
Dim rCell As Range
Dim sText As String
Dim sText2 As String
Dim iMax As Integer
Dim iLeft As Integer
Dim iStart As Integer
Dim iPrecision As Integer
Dim iScale As Integer
Dim i As Integer
Dim iDebug As String
Application.Volatile
Set rCell = rng.Cells(1)
'if not a number then error
'commented out this was breaking on 0.0
'If Not IsNumeric(rCell) Or IsDate(rCell) Then
' SigFigsMike = CVErr(xlErrNum)
' Exit Function
'End If
sText2 = Trim(rCell.Text)
sText = ""
'find position of decimal point (it matters)
iDec = InStr(sText2, ".")
If Val(sText2) = 0 Then
iLeft = 1
iScale = 0
'do this if it's an integer
ElseIf iDec = 0 Then
iLeft = Len(sText2)
iScale = 0
'do this if it's a numeric
Else
'GET NUMBERS TO LEFT OF DEC
If iDec = 2 Then
iLeft = 1
Else
iStart = 0
If Mid(sText2, 1, 1) = "-" Then
iStart = 1
End If
iLeft = iDec - iStart - 1
End If
'GET NUMBERS TO THE RIGHT
sText = Mid(sText2, iDec + 1)
'strip trailing zeroes
While Right(sText, 1) = "0"
sText = Left(sText, Len(sText) - 1)
Wend
iScale = Len(sText)
End If
iPrecision = iLeft + iScale
'return Min or Max
Select Case iType
Case 1
SigFigsMike = iPrecision
Case 2
SigFigsMike = iScale
Case Else
End Select
End Function
Yes, it's definitely possible. Countif
My biggest issue we have is that some of the bill of materials we receive here are like 900 lines long in excel, and some of the lines are the same part number and we try to count the amount of lines for each part number to get a final tally and its a pain in the ass.
My main goal would be to use a formula in that row that would let me know that there's 200 of part A, 210 of part B, 38 of part C, etc...
Anyone know if that's possible?
Pivot tables are your friend
I must be losing it. At my last job, with my Excel, I was able to split Excel files. One on one screen, and then one on the other. Now I'm not able to do that. I won't let me slide over a second Excel file onto my other monitor. What gives?
I'm 99% you're an accountant/finance guy too. I'm using this on an export from our bank transactions. Currently, I have to manually code each withdrawal based on the description. I was hoping to use this to automate that process. For example, the description contains the text "PAYROLL", return "5164". 5164 is where we book our production salary/wages.
There are hundreds of line items each month that have to be manually coded. And many of these wire/payments repeat each month. So I was going to set up an index match.
Yes, I realize manually coding stuff is old school, but this legacy system is a huge piece of shit and does not generate any journal entries. We're moving towards an ERP in the next year that will make this task obsolete.
i guess if you made a huge window you could put 2 within that same instances in it and control how much space they took up, maybe more likely is that you have 1 instance of excel open and you are looking at multiple files in it, while you actually want a 2nd instance of excel open? if that's the case, just navigate to start menu -> excel and it should load up a new instance with no files. do a file -> open from it, and now you have a totally independent instance from the other one, throw it on one screen and maximize it and do the same with the other. is that what you're looking for?
also get dis mouse http://www.thechicagogarage.com/forum/entertainment-tech/161073-hey-nerds-buy-mouse.html
