in 4 spectating
Theoretical top speed of 180 with new gears, sounds legit
[MENTION=19]Yaj Yak[/MENTION] you go if I go?
[MENTION=98]smug[/MENTION]
@whoelseisleftwitha3800?
i could be in... it'd be fun to try to hit 150 stock engine...
WGF has roll out starts too.
You guys were starting from similar times at WGF tho....no? I didnt run and I honestly dont remember.
Cars pull onto the straight, and stage until given the go ahaead/hand drop from our staff member. You stage about 400ft from the start cones (start of the measured 1/2 mile), so this gives you about 400ft of roll up distance until you hit the cones. Start cones to finish cones is 1/2 mile. Some cars do varying rolls, some do standing starts, some have jumpy feet and go early, so start late. No prizes or trophies means you never feel like you "wasted" a good run. If you jumped early, kick yourself and line back up for a clean run!
Super laid back and casual. Most like that vibe, a few have not.
Ill try to answer questions as best I can.
-Tony
Maybe Tony can touch on this more. I thought he discussed it at the actual event but I very well could be making some things and mixing up WGF things as well.
he already did in the post above.
400 foot head start to the start of the 1/2 mile... so most speeds from this event should definitely be higher than wgf speeds.
Hope that helps. We are pretty flexible and easy going. We get to be that way with participants since there's no trophies and awards or egos. It's all in fun
So it is my understanding at this event racers were allowed to "roll out" to the cones where the start of the 1/2 mile started? So if one has decided to "roll race" they would be at the starting line already moving at whatever mph? IMO if you started at the starting line already going XX mph you would have a better chance going faster at the 1/2 end then someone starting at zero at the same line. Seems cars went considerably faster at this event VS the wanna go fast. At wanna go fast we had a starting line with a light. When it turned green you could go. If you wanted to "roll race" it was up to the drivers at what speed or what point in the 1/2 to start. How did this work for guys who wanted to set a 1/2 mile MPH record? Is a standard around for this sort of thing? Two different events setup different ways. Or am I completely wrong?
I think it would be nearly impossible to go slower at this even considering you are starting from a 40-50 roll AND still have a full 1/2 mile of travel.
At WGF you would lose probably a good 4-500 feet of roll out cutting into that time, I know a bunch of people went slower from a roll, my fastest time was from a dig.
I'd hope that these 1/2 mile records are pretty much only against the ones in the same day's/weekends running. So many factors play a roll at speeds like this... hell one day could be a 20mph tail wind, the next a 20mph headwind, let alone the dozens of other conditions that would affect DA and other things.
Sorry couldn't resist.
Cmon [MENTION=22]syP[/MENTION] this needs to be a priority. Whatever else was scheduled isn't any more.....
[MENTION=12162]shanefap[/MENTION] Wagon to run too I hope!?
[MENTION=11473]JBruno88[/MENTION] You got a target date now to get that blower swap on the vette!
