There are plenty of cars that can more than handle an auto cross or track day that aren't marketed as a car that can, seems like blatant false advertising. Also I think the fact that they've remedied it the following year seems like an admission of guilt.ok.
Or maybe people should buy a race car for the track not a street car.
If Ford started marketing the mustang as a vehicle that does sliding burnouts leaving car shows, then sure.admission of guilt? Ford can easily say it was improving the product to suit the customers demands.
Again still goes back to if the owner wants to track their vehicle that hard it should be up to them to purchase the vehicle setup accordingly. OR make the necessary improvements to do so.
I could see this being a case if they ALL over heated during normal daily street driving but they dont.
Ford should not be responsible for how the consumer uses their product. Thats one hell of a slippery slope.
Where do you draw the line what next ban all mustangs from the streets because some jackass cant drive leaving cars and coffee and plowed into a crowd?
The money works both ways.
Owners want to be able to beat on their cars. Sometimes, to ridiculous extremes. Manufacturers should not be liable for abuse (unless they advertised similar abuses).
Manufacturers want to make money. Sometimes, they cut corners to make more. Sometimes, IMO (don't sue me), they know they are cheaping out. Sometimes they discover a problem after the car is in production and then cheap out.
I've never once seen a hellcat commercial where it's drag racing. It certainly should be able to do burnouts forever just like in commercials.should dodge be sued if someone breaks a drive shaft or half shaft at a drag strip? The hellcat is supposed to be the baddest drag car out currently right off the show room floor.
So should the be sued every time some owner breaks a part or something goes wrong at a track?
Where do you draw the line? IMO the answer is pretty simple.
Once a vehicle has been taken OFF the street and taken to a track all bets and warranties and liabilities and responsibility from the manufacturer is off the table. From then on its the customers responsibility and risk to whatever they subject the vehicle to.
Ford shouldnt have to pay shit here.
If the common problems were under normal street driving conditions then thats a different story.
Seems to me like Flyn said people just out chasing a pot of gold. Boohoo its always about the money indeed.
Some of you may remember that way back in 2003/2004, Chicago Mike #shoutouttoagoodFordguyChicagoMike and I publicized an alleged defect in the Terminator Cobras on Modular Fords and SVTPerformance that, IMO and other Cobra owners' opinions, caused the half shafts to pop/tink and eventually slip or break. Drag strip parking lot half shaft replacements got to be a common event after the half shafts would break at the track. Rear End Pop/Tink poll | SVTPerformance.com
Ford ended up replacing my half shafts along with Chicago Mike's and other guys who jumped in at the time. Ford's TSB called for re-torquing the half shaft nuts. IMO, this did not work and was a cheap "fix" for a known problem. IIRC, Ford, then, came out with another TSB that called for lubing up the half shaft teeth. IMO, that did not work, either. Notice, both TSBs called for inexpensive "repairs" rather than replacement of the parts. Looks like nothing has changed.
Man up, Ford. Build the cars right or fix them.
Don't forget the need for the famous head cooling mod........
Not sure what's more typical, ford marketing the most capable track mustang ever yet telling people it's not meant to be tracked or 98Grandnutswinger making every excuse in the book as to why it's not fords fault.
Diff and trans coolers were standard if I recall.what was changed in 2017 to "fix" the issue?
