I just gotta confirm something, sorry if this post upsets you but maybe it’ll serve as a reality check? Idk
You have a wife, a newborn, and a 4 door AWD BMW/mini but you prefer to put your family in a quarter million mile structurally unsound heap when roads are at their most dangerous? And now you’re looking to bandaid fix some rust and put that thing back out on the road?
Donate it or sell for cheap, write off the loss as a lesson learned. In a serious accident that thing is probably about as safe as a go cart
The mini on the other hand is never going to be a show car and will depreciate just like any other German car once the warranty is up. Take advantage of the only things it has to offer: safety and great winter driving ability
I called you last night dude.
Sorry I missed you! I have a long time friend swinging out tomorrow to get a lay of the land and take a crack at it. I'll give you a call back if this doesn't shake out well!
Side-Note, Thank you to all those that had positive input, the PO and myself are readily aware of this being sucky, shit happens and we've known each other well over a Decade.
The unibody 'frame' Rails are exceptionally clean everywhere else under the truck now that I have it up in the air on my lift with the wheels off, floor pans and even the rockers minus one small spot are also all rust free. It's like whoever was undercoating that side didn't spray it thoroughly enough, or didn't correctly prep the area so that the coating flaked away over the years. I'll post up some more pics later, its a bit of a trip.
The only stuff that's especially ugly is suspension components, which are all obviously replaceable, so I think if we can get this fixed and sealed up, we can circle back in Spring and install the re-enforcement panel for good measure to ensure its longevity.
you will break every single upper shock bolt you touch in the rear
BEEN THERE TWICE. BROKE ALL FOUR TWICE. DONE THAT TWICE
Keeping telling yourself what you want to hear... You are doing it really well
i did the air chisel fishing line technique.
and now i remember why i never wanted another one.
There is a "Flag Bolt" kit that they sell to deal with this now; which has a little flange that you can hold without having to cut the floor up:
Rear Upper Bar Pin Flag Nut for 1984-2001 Jeep XJ Cherokee [1082] | Rough Country Suspension Systems®
Work Smart, Not Hard
To install, simply knock out the factory nuts welded
so you'll still just have to air chisel rust into your eyes and mouth.
sounds fun.
right, definitely smart and not hard.
fuck these thigns.
Das, don't take this the wrong way. Your acting a s00ls.
Thank you to all those that offered to help, I had a close friend offer and he swung out and patched the rail.
Looks stout, and I’ve sealed it up with undercoat after cleaning with some heat in the garage so it should happily rock all winter.
We pulled the fuel tank for space and safety, so sorting the rear suspension is next on the “To-Do” list.
No pics ??
