LS guys - Clutch?
Gone_2022
13,094
7,525
I am not sure I have ever had a clutch assembly balanced, at least not one from a reputable manufacturer that was designed specifically for my vehicle.
From what I googled really quick the McLeod RST twin clutches are like 700-800 dollars? For that price it better be bolt in
CMNTMXR57
26,483
31,980
I have had them balanced. I had my engine builder do it when I put a better clutch in my Camaro.
Anything spinning is always subject to small tolerances and many times it's taken out of the flywheel.
So if you see a flywheel with small holes drilled along the perimeter, outside of the swept area of where the clutch disc runs on it, not all the way through mind you, and not meant for any dowel pins, that's a good indication that balancing has been attempted.
