It wouldnt hurt to clean/wash your a/c this weekend
stock-t-bird
THORNTON QUARRY
4,362
4,686
Thornton Quarry
Turn off t-stat,hose off cottonwood/grass on your outside a/c unit...do not spray hard ,it will damage the condenser fins.A simple soft paint brush can remove most of it.
Pull disconnect out to kill the power
Do not rinse while unit is running...your unit will breathe/cool much easier..just a thought...cheers
Reactions: FirstWorldProblems
P40E
9,191
4,563
Also make sure the little drain hose on the unit inside the house isn't clogged . If it can't drain it will start to fill the bottom of the unit with water and you won't know until it finds a hole to piss out of the bottom of the unit
P40E
9,191
4,563
My drain hose , for whatever reason , Likes to clog inside the 90 degree elbow coming out of the unit . So not actually just the hose can clog .
It also doesn't take much for it to start backing up . It like creates a film just enough to stop the flow of the small water coming out , and it makes it flow back into to the unit instead of draining out the tube .
NO PUKESTERS
95,848
Alright so this did not go well for me.
My advice is to go over your entire unit a day ahead with wasp killer.
When you take all screws out of the fan assembly. Put them in your pocket, not the side of the unit.
Don't do this on the hottest day of the year.
27,986
There's supposed to be a float type shut off on the bottom pan. Mine didn't work because of years of never being activated. After the A/C guys installed a new coil, I discovered they had cracked the coil pan. Water flowed through it into the bottom pan and then over the edge onto the attic door in my ceiling.
To get the A/C to work until they got a new pan, I had to let the bottom pan drip into a bucket for a few days. Sucked but at least the A/C was working. The guys replaced the shutoff as well as the pan.
stock-t-bird
THORNTON QUARRY
4,362
4,686
Thornton Quarry
what went wrong man?besides lost screws (very common)
Mr_Roboto
25,922
31,106
Window units here, no fancy centralized stuff. Radiant heat and all that.
We're getting near the time of year at my last job where they'd have to stick a hose on the top unit to keep the fucking thing from tripping off :rofl: Glad I'm not doing that shit any more, if your datacenter plant is shit you're working at the wrong datacenter.
