if i just stomp the throttle... my car will rip em off right past the 60ft mark i'd bet...
i can build 10+psi sitting still though pretty easily and quickly....
noob/novice thing, but there are no boost/exhaust leaks anywhere right?
my car had quite a few, and i almost died from a projectile bud light can trying to figure them out, but once i did, my car spools quick. albeit a "lil" turbo...
the car had rusty lines so after deleting the abs it got all new lines split f/r with an adj proportioning valve for the rear circuit, never got to finish the rear T and proportioning valve installed cause i kicked it outta the garage since the dodge's trans solenoid pack went out. i just hooked the rear line to the left rear.why 3 brakes?
when i went 12.9 or whatever my car did... i broke em loose every time about the 300ft mark or so and had to let off through there a bit and get back into it.
let me know when you snap a 300m shaft in half. buncha girls up in here.
It would be awesome of moser or strange made axles for the 3800 guys. I could only imagine the price tag on those!
Axles aren't a big deal. Internal trans parts are
Ahh sorry I didn't see Mook's post. Carry on.
Theres a vendor that gets them made for an SHO at about $1k a set, I'm sure they would make them for a GTP. However, most of the people that are drag racing leave the axles stock. Cheaper and easier to replace when they blow up. Leaves a weak link that you can control.
Whatever, after 2yrs it still hasn't done anything impressive. Clearly there are reasons for that, and it's not the cars fault. It's HK's car, his call. If he wants to continue eating up everything you whack jobs say then so be it. Under different management that car would already be in the 10's if not 9's and probably would have spent less $.
Phats car is almost instant, much less time on the brake to spool, much less throttle as well. While it's not 5 seconds in difference, the 60' times suffer. I'll bet you never break 1.9 because of that.
Car runs . No big deal.13.1...ew
Failed plot to eliminate HK from DDR.why 3 brakes?
totally ghey.
car spools fine. Get your shit straight on the T3/T4 comparison 10sec. The only thing hurting spool on this car is the weight of the compressor wheel because it is larger (and the P-trim turbine is a little on the heavy side). It is not being held back by the turbine A/R whatsoever. I do think we should check for leaks, but it didn't seem to have any last time I looked.
the real thing holding this car back is the jank fucking MAF shit that everyone is dicking around with. just put a proven fucking LS1 maf with an AFC on it and be fucking done. I don't care if it has resolution. my car guesses when it is in boost (i'm serious) and uses a "maf" table that is 8 fucking blocks. runs ok.
I feel like this car should be able to launch off idle without a problem. needs suspension mods like phatride used. slicks are not the same compound as an ET drag or a QTP either, so that could have a small effect.
just another pissing match between 10sec and the world, nothing new.
These threads are useless. Not a shred of good information presented here.
oh and my "real regal" is a turd too.
Edit:
10sec needs to realize that this car isnt going to run 11's first time out.
totally ghey.
Edit:
99+ that i modified back before we had an afc
we just need to toss a stock 99+ in there and retune
