The knock sensors go into the valley cover.
Two issues, the "mounting tab" for the steering rack on the back side interferes with the oil pan. That will need to come down a bit. And the trans mount does not line up for shit. The bracket needs to be re-drilled. I need to look further in to that before I re-drill it though, it's supposed to work the way it is. Other than that, there seems to be good clearance everywhere.
It could just be the angle of the picture throwing me off, but it appears as though there is more clearance on the driver's side than on the passenger's side; as if the engine is either rotated off center or positioned off center closer to the pass side.
Could this have anything to do with the transmission mount not lining up?
Also note that there are several variations of the T56. I'm not certain, but there's a possibility that different bellhousings and tailshafts may be of varying lengths, which would obviously require an assortment of mounts.
