There are a few different pilot bushing depths. It depends on the crank flange depth and the trans used. Next time dry fit the trans without the clutch installed and some kind of marking grease on the input shaft. Good luck!
Hot damn, I was wondering if you'd find your way over from The bimmer forums!
Welcome to TCG!
well this makes dans build look like shit... lmao
Yeah, I actually found ths board through LS1 Tech, a lot more activity here than on ETK too.
Awesome build. So how did you do your valve covers? Paint? Powdercoat?
All this work and you're using a FRAM oil filter?
My response would be, "if you want to catch any debris from the assembly process, that first start up is the most important for a good filter."
Very cool build, btw. Didn't mean to come off as a dick, I just have a hard time understanding why anyone with the slightest bit of technical knowledge would ever think of using a FRAM filter for anything other than a cap while an engine sits on an engine stand.
