Ok. So you're at the 1/4 mile track, you get a perfect launch and go 11.5@120. Next run, you spin off the line and go 12.8, but your mph increases.... why?
Like I said tho, my problem was in the launch. These stock guys were leaving on LC @ it's lowest setting of 3k and spinning (which seemed like it was required). My car was almost too hooked up and was bogging out of the hole. Basically, my computer was slowing me down for "clutch protection."
More here:
GT500 + Drag Radials + Sticky Track=#%#%
Clutch Protection Issues?
Clutch protection? What the fucking gay? Ford
There was an earlier gen GT500 but I have no clue what he ran. The orange 500 from our promo video in 2012 was also there...but I dont have times on that either.
I'm the blue Shelby. I'll settle this....
Eagle's car is just as fast as mine. I ran 151, 147, 147, 148.
He had his front splitter on. I did not.
He had drag radials. I did not.
I had a catch can. He did not.
They weren't set up EXACTLY the same, hence they didn't run exactly the same.
Heat soak was probably a major factor too. His color absorbs more sunlight and therefore gets hotter. It's not like they ran that far off from eachother.
This is the first I'm hearing of another 13-14 Shelby besides me and Eagle...
Also, I was expecting to be around 150 mph and I think it was pretty much on the money.
Totally doesn't make any sense at all If you said heat, yea, I believe that 100%. Hottest supercharged outlet temps ever. But because of too much traction?
More here:
Did you read ANY of the clutch protection links? Its the computer pulling power, not the traction. The additional traction is causing the computer to pull power from my car that it wouldn't do to the cars with stock tires.
That would effect your point a to point b time, not your MPH though. .
It was for Eagle but you posted before I finished
For reals though, the launch doesn't effect the MPH, just the ET. .
FWIW x2, I dont think there is anything wrong with Dans car. The other two 500s, aside from their sole (to my knowledge, [MENTION=669]shockerracing.com[/MENTION] & [MENTION=5219]ZXMustang[/MENTION], correct me on that) 151 passes, both were in the 140s all weekend. I think it really just came down to whos car was getting hotter. Dans intake temps were through the roof at certain points and all us blower or former blower guys know how hard that can hit a car.
He ran the blue 500 on the highway and they were dead nuts even to the point of almost plowing thru the back of me
I chalk up any disappointing runs to the heat and humidity.
