Recently purchased a 3VZE long block assembly from a shop in CO for my daughters 4 runner . Had a super competent independent do the install. Upon completion of install, the rear main started leaking immediately resulting in an additional 11 hours of labor to remove the trans and replace provided seal with a Fel Pro. As the installer was putting in the new seal, they noticed that the orifice where it sits was not perfectly round, citing possibly faulty machining. Motherfucker still leaks after thousands spent on this. I contacted the vendor and related all of this. They said they would speak to the installer if he wishes to call them, but they don't see how a "machining error" is possible. Even if I were to get all the money back on the long block, I'm still pissed that it leaks and probably will for the rest of the time its on the road.
Who do you think is the at fault party? Engine came from CO, install done in Mokena.
Regards,
Chuck
Regards,
Chuck
