So I'm sort of in a planning stage for my next build and I'd like to run twin turbos. It'll make things easier to package in a RWD car and will give me the neat option of going with a true dual exhaust system. Plus it looks cool too.
I know there are very few who have done twins because most of these cars are FWD so I haven't had a lot of luck doing research here aside from throwing guess data into compressor maps.
The only twin turbo build I'm aware of was Matt M's twin turbo build from ZZP but I don't know what size turbos they ran on that thing at all.
The goal is to be able to hit 600+ rwhp with the build while still being relatively streetable. It'll get an ST5 cam down the road, just not sure if that'll happen right away. I'd like to show off what these motors can do with stock blocks everywhere I go with it and maybe break some power records since it'll be a RWD platform that can actually handle the abuse. Ideally this will have a T56 and an 8.8 rear behind the motor.
There's also a good possibility that this ends up just being a pipe dream too
Right now I'm debating between going with some ebay gt30's or gt35's. I figure if one is good for ~600chp, two together should be able to easily hit 800hp.
GT30 is a 55mm compressor
GT35 is a 61mm compressor
Also not sure on what A/R to run on the exhaust side as well. I know spool times aren't going to be amazing with these sizes so I was leaning towards something like a .64 A/R, but honestly I have no idea if that's going to be restrictive or not on the top end when the cam comes in.
Anyone here a turbo guru?
