Welding
Ron Vogel
5,175
4,288
Ron Vogel
Get the welder's handbook before you start. Lot's of good info in there. I started with brazing before welding, if you haven't even done that I wouldn't attempt it. There are a few little prep things you'll need to do to ensure good penetration. Welding is not hard to do, just takes practice and a little knowlege of metal.
Eagle
Nemo me impune lacessit
63,909
4,744
Woodsticks, IL
Cheese is good too tho, each to their own.
Seriously tho, welding isn't rocket science. Practice does make perfect though. Best thing I can suggest is to find practice material to get your feed rate and voltage setup correctly on the TEST metal before you go to town on what you're working with. The charts don't always get the best results.
Also, the best welding tip I've learned first hand is this: a heavy extension cord makes all the difference in your welding!
32,652
16,139
i bought my first welder when i was 18 or 19 and i now have 4! my exhaust rig (first unit i bought) is a 135amp mig with two 40cuft bottles, second was a 150amp 2cycle gas power stick/scratch tig/generator, third was a miller 250amp stick/tig unit, and my newest is a low hour miller syncrowave 300 stick/tig/spoolgun (375 amps)
then you can be like me....upgrading the house to 200amp service just so you can use yer toys at WOT lol
surface prep is number one, and your teqnique will vary for your vertical and hanging welds....
prectice, practice, practice
praqctice some more.... been welding for 12 years and i'm still learning shit
btw fuck maganese lol
