Cool thanks! It looks like you either went with the Namz or LA Choppers kit.I went and did the kit through Revzilla. It was a full kit. All you needed to do was use the supplied material, some time to solder and a steady hand.
Also look at what it will run you. A fully built kit with the wires done already is a grand. You also get extra stuff with that.
I can piece together the bars, wiring extensions, and clutch cable for about $475 so I'll save a good chunk of money doing it myself. I'll just have to get a set of mirrors, trans cover gasket, and some new trans fluid and that should cover everything.
