REGISTRATION IS OPEN. PLEASE READ EVERYTHING CAREFULLY.
This will NOT be a T&T event.
We are working on having 3 classes, with a buy in for each (and of course an entry fee to cover the rental cost). The classes being discussed are as follows:
12.5 Class
- Standard Tree, Red Light is considered a loss.
- If you run faster than a 12.5, you will be disqualified**
- Breakout rule applies to the final as follows: Car that broke out the most would be disqualified.
- Redlight comes prior to a E/T Breakout, therefore the Redlight would be considered the loss.
- Cross in front of the car in the opposing lane = instant loss
- Chips will be labeled with a number 1-12 with a letter "L" or "R" which signifies the left lane or right lane. The 12.5 Class will be in the long staging lanes and we will have cones set out with these numbers on them. You draw your chip, we mark it down, then jump in your car and head to your cone in the staging lanes.
10.6 Class
- If you run faster than a 10.6, you will be disqualified**
- Chips will be labeled with a number 1-12 with a letter "L" or "R" which signifies the left lane or right lane. The 10.6 Class will be in the long staging lanes and we will have cones set out with these numbers on them. You draw your chip, we mark it down, then jump in your car and head to your cone in the staging lanes.
Overdrive Class
- NO AWD!
- Car must have overdrive trans
- If car is questioned, must be able to prove overdrive - ie ride along with staff member
- Heads up quarter mile/full tree
- You jump you loose
- Chase is not a race
- Payout determined on car count
5.50 1/8th Mile Class
- If you run faster than a 5.50, you will be disqualified
- Redlight comes prior to a E/T Breakout therefore the Redlight would be considered the loss.
- Chips will be labeled with a number 1-4 with a letter "L" or "R" which signifies the left lane or right lane. The 5.50 Class will be in the short staging lanes and we will have cones set out with these numbers on them. You draw your chip, we mark it down, then jump in your car and head to your cone in the staging lanes.
Questions about the classes can be directed to BOTTLEFED and Teege24.
