return style fuel system in 04 gtp? HELP
1quick
26,618
24,253
coal city
An fuel line and fittings, you can buy adapters to go from -6 to stock push connectors, your comp g should actually have a return off the fuel filter otherwise you have to drill a hole in the top of the canister and use a bulkhead fitting and return to that, or get an older style canister to use
MeanGreenGTP
Apr 10, 2013
92
thank u guys for tha quick responses, motor is on tha stand and i have tha money burning a hole in my pocket for zzps full i/c set up and i was just going to order fuel rails that are options to get with tha set up, i wanted to order returnstyle and it comes with fuel pressure reg,
1quick
26,618
24,253
coal city
You have to run a return line from the engine bay to the tank and boom you have a return system depending on what canister you use you can either use the stock return port and pop the factory regulator out or you use a bulk head fitting on top of the canister and return to that
