Plz sign this petition to get Mark to pulley down
119,009
blakbearddelite
29,253
9,083
FL
16lbs or bust! Or 16lbs AND bust if that's what its going to take! :rofl:
In it's current form, the KB will max out around 14psi. But if I sprung for the aftermarket oval inlet (twin 75mm's!!!), some guys are getting 18psi out of them. They're also getting significantly lower IAT's. The negative....$1,200 for the new inlet. That doesn't include labor or the new twin 75mm throttlebody that I'll need...along with some crazy new way to route the throttle cable.
Eagle
Nemo me impune lacessit
63,909
4,744
Woodsticks, IL
$1200 is chump change for a baller like you Marky! We can do the install labor and you can drive it over and get it tuned. 18psi here you come! :nutz::nutz::nutz:
