3800 pem and 3" DP with 2.5" ubend pipe
  • Thread starter imported_silverbullet
  • Start date
I
$200 for the pem. these came off my father's gtp. i bought these from tommy glover about 2 years ago and the ceramic coating on it still look good. the DP is a wbs 3" with magna flow cat and a 2.5" ubend delete pipe on the other end. should bolt right on stock exhaust. the cat has less than 10k mi. $100. i don't really want to ship. if someone is interest i can bring it to the meet tonite.
I
autometer z series trans and boost gauges both brand new. never install. $40 each. brand new lower intake gasket never open. $40. thrasher 3.4 press on pulley $30. brand new wbs mod fuel. it won't work on the monte cause the alternator is little bigger than the gtp in diameter that's why i had problem fitting. $100. L67 Tb will all the sensors except the maf sensor $30.
  • I
  • 5
  • 376
