3800 pcv valve
12secGTP
Addict
Nov 10, 2008
768
Des Plaines
you should replace them when you do a full tuneup. they are usually less than 10$. I have never heard of a HP PCV valve and I dont think you would get any kind of benefit from one. they are usually good for 20-30k.
they allow the crank case to ventilate. all engines get some kind of blow by past the piston rings. these compressed gasses get down into the crankcase and can cause a pressure buildup which if not vented properly can blow seals and gaskets.
HTH
chrys
  • F
  • 1
  • 448
