3800 ok for me to be shifting at 6000 rpm?
sweetness
Addict
Nov 12, 2008
777
If DHP has it set for 6k (really i think it is 5900) then be assured it is ok. Charles isnt up for paying for blown engines from over reving. If anything is going to go wrong it wont be your tranny. It will be a bent valve, or valve float. The issue is that the springs wont be able to close fast enough, so the valves will stay open. In all likelihood what would happen is just valve float. The valves wont close all the way, and you will loose power. Worst case scenario is a bent valve. that will happen when the valve cant close far enough to get out of the way of the piston. Ask LP3800 about bent valves. :D
BC
  • G
  • 3
  • 483
