my SI is manual... being a manual i thought it would have no rev-limit...
how can i get rid of the rev-limit
you dont want your rev limiter gone...shut up aaron
hondata reflash- but why would you want no rev limit? you arent making any more power by reving it any higher.... and the thing already revs to 8200 rpm!
rev limits at like 5000 so i want to hear it from outside the car
Errr, rev limit is 8200...?
Do you mean in NEUTRAL or while parked it won't go above 5000RPM? Thats probably there to prevent you from 8000RPM neutral drops.
ya the neutral limit...
Put in gear.....press in clutch.....rev as high as you want....problem solved
it won't let you, thats what he's saying. the civic has a neutral cut at 5K RPM so you can't do an 8000RPM neutral drop and blow the transmission.
