Nissan GT-R....one of the fastest production cars ever??
Fish
From the mean streets....
Chiraq
Supplying the power to the Nissan supercar is a new variant of the VQ engine called VR38. Almost every component of this 3.8-liter V-6 has been specifically designed for the GT-R, including plasma-coated cylinder walls, a high-capacity water pump, thermostat-controlled oil cooler and two IHI turbochargers. The turbos deliver about 11.8 psi-gauge to the all-aluminum powerplant, allowing it to pump out 480 bhp at 6400 rpm and 434 lb.-ft. of torque from 3200 to 5200 rpm. Power is sent to all four wheels via a new 6-speed twin-clutch semiautomatic gearbox (no manual is offered) and an electronic all-wheel-drive system. The transaxle and integrated awd transfer case are located between the rear wheels to help the GT-R achieve 54/46 front/rear weight distribution.
Like the DSG by Audi/VW, the GT-R's gearbox uses two separate clutches to ensure smooth gear changes when in full auto mode, while displaying lightning-fast up- and downshifts in manual mode, performed by paddles behind the steering wheel. There are three different shift maps, with "R" mode being the sportiest. This setting actually predicts your next gear change, based on throttle opening, vehicle speed and braking. The awd system is a new version of Nissan's popular ATTESA E-TS, now equipped with a yaw-rate sensor. This electronically controlled system distributes torque from 2/98 percent front/rear in dry conditions, making it virtually a rear-wheel-drive car, to a 50/50 split on slippery roads.
The Autobahn was the ideal place to sample the GT-R's prowess. There's no trick to launching the car: Put the shifter into 1st gear, and as you lift off the brake pedal, mash down on the throttle. You'll hear a slight chirp from the rear tires, and before you know it, you're gritting your teeth, as the g-forces squeeze the air from your lungs. Whether you upshift manually or leave the gear changes to the computer, the action is fast and flawless. After about 9 seconds, you're going 100-plus mph. I maintained a speed of 175 mph on a nearly empty stretch of Autobahn, and the Nissan was quiet, steady and smooth...so well-mannered at this speed that I enjoyed a conversation with a passenger. The GT-R's slippery CD of 0.27 keeps wind noise minimal.
Kazutoshi Mizuno, project leader of the GT-R, said the 3835-lb. car accelerates from zero to 60 mph in 3.5 seconds, and to the quarter-mile mark in 11.7. He emphasized that he used R&T's road test procedures as a guideline — his assistant actually called us during their test to ask about the spacing between cones for the slalom. If he got everything right, the GT-R is among the fastest production cars in the world.
The handling portion of our evaluation occurred at the Nürburgring's south course, home of the German Grand Prix. It has a variety of corners and elevation changes that'll challenge anything on four wheels and punish brakes and tires. Our silver test car felt right at home around the 3.2-mile circuit. The structural rigidity of the GT-R is rock-solid. The suspension, toggled to "R" for this venue (there are also Comfort and Sports settings), felt race-car stiff and provided excellent stability through all variety of turns — the GT-R just wouldn't get out of shape no matter how hard I pushed it. The suspension system consists of upper and lower A-arms in front and a multilink setup at the rear, with Bilstein dampers all around. Giant 15.0-in.-diameter Brembo cross-drilled rotors and 6-piston calipers up front and 4-pots in the rear do a commendable job of slowing the GT-R.
After the last car pulled into the pits, the GT-R test session came to a close for everyone...that is, except for R&T.
A few months after the Nürburgring event, Mizuno gave me a unique opportunity to sample a left-hand-drive U.S.-spec GT-R. As soon as I took the first corner, it was immediately noticeable that something was different. The handling balance seemed better than that of the previous car — there was more compliance to the shocks and springs and improved steering feel. What's more, ride quality was definitely better. Mizuno said that he slightly retuned the suspension, making it more civil but without sacrificing handling. Also, he noted that the lateral weight distribution of the car is better in left-hand-drive configuration because the driver's weight offsets the weight of the front differential and driveshaft, both located right of center.
That Nissan used the Porsche 911 Turbo as the benchmark for the GT-R is no secret; simply look at the hundreds of spy shots of the masked Nissan, and you'll see a Porsche 911 Turbo close by. Mizuno's aim was to surpass the German thunder car in every category, while keeping the price at just over half of the 911 Turbo's MSRP. We'll find out if he succeeded when the GT-R goes on sale in June 2008 (Japan's on-sale date is December 2007).
Source: http://www.roadandtrack.com/article.asp?section_id=7&article_id=6201
El Presidente
basically a repost from all the humping ive done for the past 6 months but i wont turn away another fan
however, this isnt technically "news" so i'm gonna move it to general car
Fish
Fish
Chiraq
I wasnt sure if some of the points were brought up. I got a kick on how the US version handles better then the Japanese version. :rofl:
El Presidente
makes sense tho as to why
and believe me...i dont think theres anymore points that can be brought up...for awhile i was posting weekly about the car
El Presidente
yep....been posted somewhere in auto news i believe
Fish
Fish
Chiraq
I fail...........
Tell ya what Mook, if I win this lotto tomorrow, Ill buy you one in every color. We just have to think of something degrading for you to do to get the keys and titles.
PANDA
FRG
"one of the fastest production cars" yeah one of MANY 11 second 175+ mph cars. Im not going to argue in this thread though.
