Need to know a cost....
O
oohsoobad2
It will be tough to estimate how much its gonna cost until you are for sure whats has gone wrong. Usually low compression is a sign of worn rings. If that is the case then your talking a full bottom end rebuild. However, other things such as a bad head gasket, broken piston or burned valves could also cause low compression. Your best bet now is to pull off the heads and see what you find... Good luck !!
  • B
  • 1
  • 319
    Participants list
