Use your knock sensor to determine the pulley size and/or timing to run. No knock, add some timing or pulley down. If it's knocking, go the other way.
The higher compression L26 will just push you closer to the KLSA (knock limited spark advance) sooner. So either a bigger pulley, or less timing.
If you're not watching the knock sensor, then you're driving/tuning blind.
I was running a 2.9" pulley with 24* timing and everyone was freaking out about it being too much. I had zero knock most of the time (just a little knock once in a while). I dropped to a 2.7" pulley and backed out 8* of timing (back to stock 16*). I then added 4* until I was on the edge of knock again. In the end, car ran the same ET either way.
