3800 Misc. Parts/Heads/Bolts/Rockers/Gaskets
98 TGP TOY
2,167
Morton, IL
L67 Ported/Polished heads. The intake side has been gasket matched and slightly ported. The exhaust ports have been slightly ported. The bowls, intake ports, and exhaust ports have been blended and polished. They came from a 98 with 75,000 miles. There are no visible cracks. $300 + shipping
Brand New Felpro Head Gaskets $25 + shpping per gasket
Brand new Felpro Head Bolts (Head bolts are TTY) $20 + shipping
L36 Lower intake manifold $30 + shipping
L67 Stock Rockers. 3 full sets. One set only has 300 miles on them. $30 + shipping for a set
L67 Push Rods. Only has 300 miles. $30 + shipping
2.75" mild steel tube with 90* mandrell bend $10 + shipping
2.75" to 3.0" mild steel adapter $10 + shipping
2.5" mild steel tube with 90* mandrell bend $10 + shipping
4AN Steel braided hose, 3 feet with female fittings on each side $15 + shipping
8AN Stell Braided hose, 3 feet with female fitting on one side, and 90* female fitting on other $10 + shipping
L67 EGR valve $15 + shipping
L67 block that through a rod bearing. Pistons and rods still in the block. Scuffed bore. $25 + pick up
Home Made Happy knob. Requires a scanner to set timing points. Has two separate dials available for timing adjustments, with a switch to go between. $15 + shipping
Shurflo Pump 8000-543-236. Great for an alky kit. Slightly used, but in great condition, and tested good. As seen here. $50 + shipping
Cooling Mist Alky Solenoid. Brand new, never used. $25 + shipping.
M10 and M15 Nozzles $5 + shipping each
If you have any questions, PM or post them. I can provide pictures and additional info upon request. Thank you.
  • 9
  • 2
  • 475
