Mechanic recommendations
blakbearddelite
29,253
9,083
FL
I have a mechanical issue that's outside my skill set. I can do brakes and some other minor repairs.
But I have a squealing engine bay that's been driving me crazy for 1.5 years now. I don't know if it is a pulley or a belt. If I took the belt off, I'd never get it back on. And if I did, my accessories would likely be running backwards and I'd probably skip the water pump. Plus if I do it myself, it'd probably take me a month as I struggled through the trouble-shooting of the actual problem.
I'd rather send it to a mechanic for a day and have it done right.
I'm in the South Elgin area, but it doesn't have to be in South Elgin. But I don't want to drive two hours either. There has to be some local. Maybe Dean's in St. Charles?
1quick
26,610
24,225
coal city
Correct sir. It started as a barely audible squeak a few months after the blower install. And then by the end of the year in 2017, it was a full on scream. And 2018 came and went without me putting a ton of miles on it and addressing the noise.
Dmark performance, or speed inc just started doing mustang builds, taking the belt off isn’t a big deal it can be a pain in the ass but I change belts at least once a year it seems like, finding a squeak would be my weak point
Pressure Ratio
20,514
12,424
Glen Ellyn
Herbst High Performance
(312) 933-5083
He's an honest guy and does good work on about anything. Pratt uses him a lot too and can vouch.
Ya, Eric and crew do great work and are very trustworthy. They work on everything from dump trucks, to high-end exotics, to old school carb'd hot rods, to modified late model cars. They are very versatile and knowledgeable.
They even have loaner vehicles if needed/available. They have two 2019 Chevy Equinox I believe.
lefty
Addict
Aug 23, 2015
569
426
It's not that hard to remove and install belts. Take a picture of it before you pull it to make sure it goes back on the same way, plus there should be a sticker under the hood to show you how it goes on. A mechanic's stethoscope works wonders on narrowing down squeaks from pulleys.
blakbearddelite
29,253
9,083
FL
Thanks to [MENTION=945]daturbosix[/MENTION] and [MENTION=60]greasy[/MENTION], the Mustang is back on the road and without squeak.
There were a couple things going on. The first one is that one of the idler pulleys was not in the right spot to provide tension on the belt. And the second problem was that one of the other pulleys was out of alignment. Jeff shimmed with a washer and it is now in alignment. Jim threw on a new belt and all is good.
daturbosix
HNIC @ GoodFellas Garage
16,460
15,458
Jeff
