LOL
whats that red breather for? PCV?
it looks like its on a breather or oil catch can but its odd that it connects to the fresh metered air fitting on the N* TB then goes to the catch can and i can see a line tapped into the fronts 04+ fill neck, i dont get why there's a filter there since it would cause a vac leak condition with unmetered air entering the pcv system/tb area
I need land from this 13 second regal.
I have 3 regals, I win.
but you dont need the catch can on the metered fresh air supply side of the pcv system. you put those kinds of oil seperators in between the pcv valve and the vac port of the intake, that way it takes the oil vapors out of suspension keeping it off the ic and out of the combustion chambers.
its really easy to install on an external pcv system but to keep the oem pcv valve location you have to tap the top plate and un a 90* nipple with an inside hose to the pcv valve that runs the oily air to the catch can, then drill and tap the pcv housing for another nipple to pass it back through from the catch can into the blower inlet.
this gives ya an idea of what i mean
