doesn't mean its going to work for you motherfucker
From what I see, the Regal has a tighter engine bay then the GP. The rear SLP header is a bitch already on the GP. Im not looking forward to it on the Regal.
got a question. where the hell does that small heat shield go on stock exhaust? it goes on one of the 2 bolt connections.... front or rear on the crossover?
its been a while since ive had stock exhaust...
rear x over connection to the rear manifold, two bolts with the studs on top go in the rear connection and are tightened then that shield goes over the stud portions and are secured with nuts.
np man all my demods have been complete OEM demods so i keep plenty of hardware around in case its neededthanks for the offer though.
eh not if you know what your doing. i just pull the dogbones and use a threaded rod and pull the engine forward a few inches. makes getting the rear one on a breeze.
