I’m like 95% sure this wall is load bearing. Just the fact it’s got a double top plate says yes. What do you armchair engineers and architects think?
A little background:
Ive got a partial crawl space attached to my basement with a concrete wall about 4’ tall
The wall in question (blue) is built on top of the concrete wall. Previous owner knocked out studs in two different spots for larger access holes into the crawl.
There is a double joist (green) that bears on a steel beam (red) that the joists in the crawl are attached to. The floor joists also change direction at the double joist that bears on the beam. Yellow lines are joists/direction
I want to keep the openings so I can continue to use the crawl space for storage but floor is sagging upstairs. Probably going to end up tossing jacks and beams between the sections that were opened up, there isn’t enough space to build a header and have a usefully sized access into the crawl.
